i updated roll bar with new generation feature
back to sqaure one
https://cimg8.ibsrv.net/gimg/www.rcu...04a18842ff.png
take out the plastic ball cup and set screw
put in each lower suspenson arm ball mount where the ball cupz go
a turnbuckle ball
slide in your bar az u shape
all it doez iz increase oposite side tire with the same kenitic energy
how many damn turnz iz dat !!!!
rip it so fast i cant tel what i made some one stole it
hara atsushi
damn man
when you compress both suspesnion arm left right rear
it doez nothing
i cant even type
racerz in my head for the product
a turnbuckle ball
hara atsushi
damn man
it doez nothing
i cant even type
i keep seeing
that you can do a roll center bar
or you can do my grip bar
here iz my grip bar
you put the turn buckle ballz in the bar mountz
any turn putz energy in to the other tire
we all know that that createz nothing but
grip
like downforce
since there iz no downforce needed there iz no drag to have a spoiler do it with drag
so we reduced drag
when you lift but suspension armz
it doez nothing nothing at all like there iz no bar
the bottom ball mount can be a shaft mount mmmm
i liek this idea
but by it self
not with roll center added to it
i can draw this up later
i am off to bed
i will psot it when i am done and it iz a GRIP BAR by self haz nothing to do with a roll center bar
i agree
this iz a hard thing to do
to combine both
my grip bar
and a hudy team xray roll cente rbar
here iz my grip bar
grip
like downforce
so we reduced drag
i liek this idea
but by it self
i am off to bed
i agree
to combine both
my grip bar
alright
i took this prototype of my grip bar that you can lift one side of the suspension and compress the other to increase oposite tire grip
but with this prototype you can not compress both suspension arm and made
this from that prototype
you can compress suspension
so now the prototype
iz
finished
iz
finished
now take my grip bar
and make it option part a
and take team xray t4 2018 roll center bar and make it option part b
you can chooze a and or b
but you can not chooze both
so then both iz
our future bar that iz would be the same az electricity for fusion
they will be fuzed
so then both iz
they will be fuzed
here another idea
when you compress both lower suspension mountz the c tab that haz two screwz so it arc with the lower arm az a curve cut in side it
if you put a bar in there and let go it tipz and anglez and doez not do any thing but if you lift one side it grip the other side to push it down mmmm
#32
out of thoze 3 i choze az final
i am at this one
az this iz the best one out of all of mine
it had only one problem
when you sit car you can twist bar at a angle
doez that un angle when you drive for a short distance
i am at this one
#33
you can find it hard to design this stuf
andi found out why
and it iz the same thing i want changed
the sway bar iz round and not square and or not sqaure end to lock in set screw for any concern of a slip
i will put this on my stuf and post what i think i want after all of this stuf iz posted
it wont be much like 2 or 3 diferenti filez
i cleaned up that one i jsut posted and put a double bearing
for the center axis
it a easier to make
andi found out why
for the center axis
it a easier to make
#36
here iz another i am creating
the onez i choze before the onez i posted above the 5
i had chozen some angle onez with a bottom shaft at a angle
i choze it to remember it and this iz what it iz to be
2 anglez not one and it push back to lift suspension and can push down oposite side tire
i have to make the lower ball mountz shaftz
#37
i change the angle and up date the ball mount
it iz hard to see if this angle work
compare to the other one above post
with this set up
my grip bar can go left to right but not lift both suspension
team xray t4 2018 can lift suspension but not go left right
combine with fusion it iz both like below but at half the power to lift half the power to grip
with this set up
#40
i remember now i waz to angle this az
the angle cylinder not perfect to the above angle
here it iz !!!!
my final prototype
and i think it iz my best version out of all of them for price part count eaze of assembly it cheap and the geometery of the angle lower bal
lower suspension arm shaft take the center ball cup that can az a car siting angle left right horizontal and it removez that ability that mean
when you drive it it iz at a angle the bar but with this angle mount the cylinder it can not angle akward
i have chozen theze 3 for my finalz i could add the ball but it for now are theze prototypes
edit i forgot to mention there could be a precise angle not just a 45 degree to this
my final prototype
#42
My theory... it would be a heck of a lot easier to type like a normal person than to make up one's own alphabet. Yes?
Why go through all the trouble to misspell your words? You put all this time and effort into your theory, to be looked at by others, and it kinda comes off looking/sounding ... weird.
#43
what
shield
May 20, 2018 - Just when you're feeling good and solid in your plan, Taurus, something or someone may step in to rain on your parade. You could get the feeling today that you're taking one step forward and two steps back. Perhaps there's a feeling of doubt creeping into the picture. Try not to let these nagging, restrictive energies hold you back. Be confident about your abilities.
typical
shield
typical
#44
Moderator
