Reload this Page >
BIG A-5 Vigilante build
Old 03-08-2016, 10:58 AM
  #301
jofunk
The excess glass got trimmed off and I was able to flip the fuse over. I was interested to see the top and to start figuring out the next set of engineering challenges. I stuck all the pieces where they go to get a sense of size. I looks like it will be a nice everyday flyer. You know, just toss it in the car and go………………. I brought the fuel bay stress analysis team down stairs for some preliminary load testing. So far so good.
ID:	2151469   Click image for larger version
ID:	2151470   Click image for larger version
ID:	2151471   Click image for larger version
Old 03-13-2016, 04:57 PM
  #302
jofunk
I glued in some balsa to start feathering in the step in the intake. I laid T stock in the nose gear box and in the fuel tank bay. I dyed the epoxy red to see where I covered, and just a little goofing around. Everything got wedged in with some scrap balsa.
ID:	2152463   Click image for larger version
ID:	2152464   Click image for larger version
ID:	2152465   Click image for larger version
ID:	2152466   Click image for larger version
Old 04-08-2016, 08:46 PM
  #303
jofunk
A slow go with Easter and a trip to Disney World. Although I did visit Graves RC in Orlando. I messed around trying to figure where the tops of the 3 missing bulkheads go over the wing mount box. I will also need to build a hatch into this area.
Old 04-08-2016, 09:02 PM
  #304
jofunk
Here is a better picture of the fuel bay stress analysis team at work. Notice the simultaneous rearward and sidewall inspection in picture two.
ID:	2156480   Click image for larger version
Old 04-09-2016, 05:41 AM
  #305
rhklenke
My Feedback: (24)
rhklenke's Avatar
Neat project Joe! I can't wait to see it!
BTW, I would recommend that he not wear a shirt that says "Kiss me" when he goes to High School!
Bob
Old 04-09-2016, 08:56 PM
  #306
jofunk
He should out grow it by then………….I glued on the missing three bulkheads, twice. The first time they were too high. I used some tape over the top to see the lines. I also glued a top onto the nose gear box.
ID:	2156577   Click image for larger version
ID:	2156578   Click image for larger version
Old 04-14-2016, 07:42 PM
  #307
jofunk
I glued some straps across the tops of the intakes to stiffen them up since they are out there floating in space....I also made a strip to terminate some stringers. In this area the flat fuse top and the curved top of the fuse converge between two bulkheads.
ID:	2157429   Click image for larger version
ID:	2157430   Click image for larger version
ID:	2157431   Click image for larger version
Old 04-15-2016, 10:00 PM
  #308
jofunk
Wrong picture. Here is a picture of the straps on the intakes. I cut two holes in the top of the engine box. This is where I will be inserting and removing the pins which will hold the hoz. stabilator. They will need to come off for transport. I laid some stringers down. They are helping to give me a visual on where a hatch will need to go. It looks like the full length stringers will be the width of the hatch.
ID:	2157557   Click image for larger version
ID:	2157558   Click image for larger version
ID:	2157559   Click image for larger version
Old 04-19-2016, 06:38 PM
  #309
jofunk
This is what happens when you elbow your bulk head as hard as you can doing something else. I started to box in the hatch area. The sides of the box are hooked under the wing spare with a couple of gussets to stiffen things up. The hatch will be material doubled up inside this area. It will be cut out after everything is sheeted and shaped. I also hacksawed some slices for the stringer locations.
ID:	2158182   Click image for larger version
ID:	2158183   Click image for larger version
ID:	2158184   Click image for larger version
ID:	2158185   Click image for larger version
Old 04-20-2016, 06:34 PM
  #310
jofunk
A few more stringers over the intakes.
Old 04-21-2016, 06:26 PM
  #311
jofunk
I sharpened the corners on the hump to make it easier to sheet into. Tight inside radii are very difficult to sheet. I put a support under # 11 to the top of the box to stiffen things up, and more stringers.
ID:	2158412   Click image for larger version
ID:	2158413   Click image for larger version
ID:	2158414   Click image for larger version
Old 04-30-2016, 06:52 PM
  #312
jofunk
The gussets were not enough. I needed something to terminate the stringers on between the wing plug ins, so I added some partial bulkheads.
Old 05-08-2016, 07:46 PM
  #313
jofunk
I reenforced another bulkhead, and finished stringing the top. I was finally able to start sheeting the top. The two 36" pieces curve over the top so I used quite a bit of weight to hold things down. To give me more time with the big pieces they are glued down with urethane glue. the only drawback is the over night curing time. The smaller pieces of sheeting in the rear are glued with CA.
ID:	2161663   Click image for larger version
ID:	2161664   Click image for larger version
ID:	2161665   Click image for larger version
ID:	2161666   Click image for larger version
Old 05-11-2016, 08:08 PM
  #314
jofunk
I put more sheeting on in the back. One piece was too big to use CA so I used urethane and a few bricks. I had to build up the side of the intake a little to close it up when the top sheeting comes over...... My combat plane got cut in half in an aggressive combat session so I needed to make another wing.
ID:	2162097   Click image for larger version
ID:	2162098   Click image for larger version
ID:	2162099   Click image for larger version
ID:	2162100   Click image for larger version
Old 05-15-2016, 09:29 PM
  #315
jofunk
I started closing in the rear of the fuse. There is a radius on this corner that transitions into a right angle somewhere near the TE of the wing or a little forward of the TE. I need to look at some pictures.
ID:	2162757   Click image for larger version
Old 05-16-2016, 08:50 PM
  #316
jofunk
The radius starts 4 " in front of the TE. With the corner square I cut back 1/2 inch on the top and side. I ground down the radius on the bulkheads and sanded the sheeting down on a 45 degree angle. I capped it with a 1/4" piece of balsa and rounded that. The radii on the bulkheads top corners were too tight to sheet. This way there is some material back there.
ID:	2162876   Click image for larger version
ID:	2162877   Click image for larger version
Old 05-17-2016, 08:17 PM
  #317
jofunk
I notched some sheeting to save on some trimming. The sheeting is the top of the intake. I also cut off the extra material above the intake.
ID:	2163041   Click image for larger version
ID:	2163042   Click image for larger version
Old 05-18-2016, 08:07 PM
  #318
jofunk
I finished sheeting over the intakes. The sides of the intakes are wrong on the Trumpeter kit. The inboard and outboard edges are not straight, they are curved. Also the inboard edge does not stop at the LE of the intake. It runs up to the notch just behind the LE.
ID:	2163149   Click image for larger version
ID:	2163150   Click image for larger version
ID:	2163151   Click image for larger version
ID:	2163152   Click image for larger version
Old 05-18-2016, 08:09 PM
  #319
jofunk
I'm not a super scale guy but the intake shape is easy to change.
Old 05-19-2016, 01:55 PM
  #320
Jet20
If I remember right, the earlier Vigi's had the curved outer inlet edge while on later ones it was straight. In both cases, the inboard edge curved to the bottom of the inlet which is definitely wrong on the plastic kit.
https://upload.wikimedia.org/wikiped...VAH-7_1979.jpg
Old 05-19-2016, 02:44 PM
  #321
turbofixer
Hi Chris,
You are correct that the last block of RA5 had the straight outer duct edge. You can also note that late block aircraft have the strake from the wing to the front of the intake duct...I have learned a lot lately about the viggy converting the Golds kit..Talk about sport scale..argh
Fellow RA5 fan...Scott
Old 05-19-2016, 07:21 PM
  #322
jofunk
Thanks for the good research guys.
Old 05-28-2016, 08:33 PM
  #323
jofunk
OK the LE of the intakes is going to be straight. I worked on the inboard sides while the outboard sides are still open. I cut the curve and straight line and cut out the former, The side is doubled up with some stiff balsa. It will get glassed and then some urethane foam to feather in the step further in the intake. I clamped a plank on the outboard side to see what is visible in the intake. I also doubled up some formers to create a hatch. It will get sheeted, get stiffened with some glass, and then get cut out. The last picture is for Sierra Tango. I was practicing squeezing rivets. Some I purposely messed up to see what happens.
ID:	2164802   Click image for larger version
ID:	2164804   Click image for larger version
ID:	2164805   Click image for larger version
ID:	2164806   Click image for larger version
ID:	2164807   Click image for larger version
Old 05-29-2016, 08:04 PM
  #324
jofunk
I glued on a piece of 1/32 aircraft ply to the LE of the intake to save the straight edge. The plywood had some glass and paint on it from a previous wreck of something. I filled in the underside of the tops of the intakes. The pieces needed a little shim to get them flush. I also glued some sticks between the sheets to stiffen them. The outboard intake walls got added and the angle cut. It looks a little more like a Vigilante.
ID:	2164995   Click image for larger version
ID:	2164996   Click image for larger version
ID:	2164997   Click image for larger version
ID:	2164998   Click image for larger version
ID:	2164999   Click image for larger version
ID:	2165000   Click image for larger version
Old 06-08-2016, 08:24 PM
  #325
jofunk
I put the last of the sheeting on the sides and slid out the aluminum bars. I rotated the fuse on the table 90 degrees to jig up the wing.The top of the wing airfoil matches the top of the fuse pretty well with the trailing edge running down the way it should. When I got the tops to match the incidence meter read not even a 1/2 degree Positive. That is encouraging.....................Here are a few pics of my Memorial Day salute. The axis planes stayed in the garage.
ID:	2166961   Click image for larger version
ID:	2166962   Click image for larger version
ID:	2166963   Click image for larger version
ID:	2166964   Click image for larger version
