Reload this Page >
BIG A-5 Vigilante build
Old 04-10-2018, 07:26 PM
  #476
jofunk
I put some rivets on the hatch then steel wooled them. Then it will get another coat of paint
Old 04-11-2018, 07:37 PM
  #477
jofunk
All the control surfaces and the recon. canoe got sprayed with primer
Old 04-12-2018, 07:45 PM
  #478
jofunk
The silver canopy came out ok. The tape lifted some of the silver. I test burned some rivets on the recon canoe. They came out good. That saves painting the plane twice to burn the rivets into a first coat of paint.
Old 04-13-2018, 09:10 AM
  #479
dc10capt
Default wow!
Really Nice. My dad Lt. Cmdr. H.A.(Speed) Moreland flew the A-5 in RVAH-7. I'd love to see the finished project. please keep me posted.
Old 04-18-2018, 05:40 AM
  #480
jofunk
Thank you Lt. Cmdr. Moreland.......... The weather is still awful here but I managed to go outside and paint the recon. canoe. It looks pretty good. (very white)
Old 04-18-2018, 05:41 AM
  #481
jofunk
Old 04-19-2018, 01:20 PM
  #482
jofunk
some rivets on the control surfaces
Vladimir machined some new fittings for the new tank plug.
Old 05-06-2018, 04:10 PM
  #483
jofunk
some panel lines and rivets
white bottom and white trim you
rudder with panel lines and rivets and chart tape where rudder hinges over
tape off for the gray top
gray sprayed
tape removed
elevons and rudder done
Old 05-06-2018, 06:03 PM
  #484
jofunk
the flaps are also painted
Old 05-07-2018, 10:46 AM
  #485
turbofixer
Looks great Joe
Old 05-08-2018, 08:29 AM
  #486
ps2727
Looking great!
Old 05-08-2018, 10:12 AM
  #487
dc10capt
Wow! Really Nice!
Old 05-08-2018, 10:17 PM
  #488
jofunk
Thanks for the encouragement guys...... Its just a slow go.
Old 05-09-2018, 04:27 PM
  #489
rhklenke
My Feedback: (24)
rhklenke's Avatar
Yea, but when you finish it, its going to be awesome!
Bob
Old 05-20-2018, 07:54 PM
  #490
jofunk
Mid 50s for a temp today and a chance of rain but I squeezed in priming the hatches and fuse.shot them outside then brought them inside to dry........ I put nick i the pic because he keeps telling me he is almost as tall as me.
Old 05-23-2018, 08:29 PM
  #491
jofunk
I put a few rivets and panels in the primer on the hatches
I made some templates to scratch some panels into the primer
Old 05-28-2018, 07:03 PM
  #492
jofunk
this was the best way to draw the line where the white and gray paint meet
some rivets and panel lines on the top front of the fuse
some rivets and panel lines on the top rear of the fuse. they will all need to be subdued with some steel wool of light sanding
Old 07-24-2018, 05:40 PM
  #493
jofunk
Let there be white.......I painted the bottom of the fuse white the top is still primer. I taped things off so I wouldn't have to cover the white overspray with the gray. When it dries I will flip it over and put the gray on.
Old 07-25-2018, 09:18 AM
  #494
turbofixer
It looks great Joe. Really wish I could see this fly
Scott
Old 07-31-2018, 04:34 PM
  #495
jofunk
Thanks Scott..............I got the gray on after running the fuse and nose in and out of the basement a few times to avoid the rain drops.
Old 07-31-2018, 04:46 PM
  #496
jofunk
The gray on the nose and the gray on the fuse are the exact same color. You wouldn't think so in that last picture. It's just a matter of how the light is hitting it.
Old 08-12-2018, 05:24 PM
  #497
jofunk
the servos for the elevons and rudder went in
some of the nice linkages Vladimir machined for the plane
I had center marked in the primer then I painted over it. I had to remind it.
The arm for the rudder servo wit some temp. linkage
Old 08-12-2018, 05:33 PM
  #498
jofunk
dremmeled open some slots for the linkage
A few tabs of hobby foil to keep primer out of the threads
some bottom primer on the wings
some primer on the tops of the wings. the sticks are holding things open so the primer doesn't glue anything shut
Old 08-14-2018, 07:24 PM
  #499
jofunk
Some G 10 for the ears on the rudder servo hatch
And a nice countersunk screw down to the g 10
I precisely marked where the clevice pin holes needed to be drilled
and then precisely drilled on the wrong side of the line
a clevice pin made out of 4-40 rod
pin installed
Old 08-14-2018, 07:33 PM
  #500
jofunk
some more nice links for the for the elevons machines by vladimir
here they are glued into the hard wood blocks sunk in the surfaces
my modified Robart incidence meter for giant scale. I taped the block on there so it couldn't slip off. I marked 0 incidence on the tape.
Now to figure out to elevon linkage. and arm lengths. they sorta blend into the white
