Reload this Page >
BIG A-5 Vigilante build
Old 05-24-2014, 01:48 PM
  #76
jofunk
I didn't think the lines on the drawing were that visible. Next time the drawing is rolled out I will take more pix.
Old 05-24-2014, 11:53 PM
  #77
jofunk
I started cutting some foam. the inner wing panels were a bit of a challenge. I had to stand on a bucket to reach over the cores to start the wire. The tips were much easier. The tip template was so thin I didn't try putting a nail in the center line near the trailing edge. If it wasn't perfectly straight It could catch the wire. I supported the template with some finishing nails under the template. The tip core TE needs to be cut on a different angle and then sanded back to the airfoil shape then the sheeting can start. After that the tip can be glued to the inner panel.
ID:	1998025   Click image for larger version
ID:	1998026   Click image for larger version
ID:	1998027   Click image for larger version
Old 05-27-2014, 07:17 PM
  #78
jofunk
I cut the TE on the Vigilante wing tips back and resanded a sharp TE on them. I also sheeted and vacuum bagged the wing tips. Next is the inside wing panels.
ID:	1999113   Click image for larger version
ID:	1999114   Click image for larger version
ID:	1999115   Click image for larger version
ID:	1999116   Click image for larger version
Old 05-31-2014, 07:03 AM
  #79
jofunk
Here is a pic. of the wing tips sheeted. I also made a skin for the main wing panel. I applied some lite filler to the cores. When it is dry they can get bagged.
ID:	2000170   Click image for larger version
ID:	2000171   Click image for larger version
ID:	2000172   Click image for larger version
Old 05-31-2014, 06:43 PM
  #80
jofunk
I got one wing panel in the vacuum bag. I am just about at my limit width wise.
Old 05-31-2014, 06:49 PM
  #81
sysiek
My Feedback: (176)
sysiek's Avatar
Hi I know the size of you table and the wing must be giant .
Old 05-31-2014, 07:48 PM
  #82
jofunk
Hey Sebastian,
The wing is on the larger size. the table is 4'x8'. One other thing, on all the skins the wood is not edge glued. The only thing holding the pieces together is the tape.
Old 05-31-2014, 08:03 PM
  #83
sysiek
My Feedback: (176)
sysiek's Avatar
The fiberglass grassing will do the job ,this might be the solution to have the wing perfectly curved without steps from glue .
Old 06-01-2014, 12:39 PM
  #84
jofunk
Here is a shot of the wing panel with the tip next to it. Its a good look at the TE feature.
Old 06-03-2014, 05:15 PM
  #85
jofunk
The other main wing panel made it into the vacuum bag. When done it will get trimmed down and both wings will get a LE to help support the outer panels.……. After I trim the over hang of sheeting I scribble marker all over the root , tip, and LE exposed foam. The marker works as an indicator to let me know when to stop sanding………………… I hate wasting resin.
ID:	2000953   Click image for larger version
Old 06-04-2014, 02:06 PM
  #86
jofunk
oops! some how I cut two right wing tips. There was enough meat in the saddles to recut a left tip. Actually there is enough to screw up three times.
ID:	2001120   Click image for larger version
ID:	2001121   Click image for larger version
ID:	2001122   Click image for larger version
Old 06-06-2014, 12:54 PM
  #87
ps2727
What scale will this be?
great project
paul
Old 06-06-2014, 01:40 PM
  #88
grbaker
My Feedback: (29)
grbaker's Avatar
The size is going to be somewhere between 1/6 and 1/7 scale,
from the first post of the thread
Old 06-06-2014, 03:04 PM
  #89
jofunk
Close to 1/6. Like i said so GI joe can fly it. The old dolls are about a foot tall so they should fit. The length of the fuse is going to be 139" and the vertical sweep hangs a little over the back of that. I have an extra wing tip if anyone wants to start one. : )
Old 06-09-2014, 06:09 PM
  #90
jofunk
I C temped the vertical root and tip airfoils and transferred it to a piece of formica. I also glued a few sticks together to get the plan view of the vertical stab.
ID:	2003032   Click image for larger version
Old 06-11-2014, 07:42 PM
  #91
jofunk
I cut a vertical stab out of some less dense foam. Thew thickness of the the foam left no room to spare. Take a look at the saddles at the root. It will get some sheeting and then a post will eventually be engineered into it to make it a flying stab.
Old 06-12-2014, 04:06 AM
  #92
jsjshjshu
Thats a big ship. Excellent project. I'll be following.
Old 06-13-2014, 06:50 PM
  #93
jofunk
I made some skins for the vertical stab. I need to do some light sanding on the foam core and then it can go into the vacuum bag.
Old 06-14-2014, 06:57 PM
  #94
jofunk
ok the vertical stab is in the vacuum bag. the Gast vacuum pump runs constantly with a bleed screw dropping the vacuum down to 6 or 7" HG. Full vacuum would crush the foam.
Old 06-16-2014, 06:38 PM
  #95
jofunk
I cut a foam block to the plan view of the elevators. It should be thick enough to get both of them out of it.
Old 06-29-2014, 04:44 PM
  #96
jofunk
Here is a mock up of a 1/6 scale Vigilante main landing gear with a 6" wheel that Paul down in texas did. He said he would be happy to let me use it to fabricate a metal gear from. Absolutely amazing! https://www.youtube.com/watch?v=kkngrNpVyW8
Old 07-22-2014, 06:34 PM
  #97
jofunk
I cut some foam cores for the hoz. stabs. I also started on making some skins for them. It is like ground hog day with cutting foam cores and making sheeting for them. I am trying to make all the reasonably sized pieces of the plane before I start to stand up the fuse.
ID:	2016422   Click image for larger version
Old 09-23-2014, 05:13 PM
  #98
jofunk
I graded a bunch of sheeting I had and made the other three skins for the horizontal stabs. they both fit in the vacuum bag together. That saves some time. This is it for the foam core sheeting. It was finally nice to get a little work done on the Vigilante.
ID:	2034635   Click image for larger version
ID:	2034636   Click image for larger version
ID:	2034637   Click image for larger version
Old 09-24-2014, 05:54 PM
  #99
jofunk
The horizontal stabs came out of the vacuum bag. The horizontal and vertical stabs got a leading edge glued on. I used Elmers white school glue to attach the LE. The Elmers is quick and easy and I don't mind waiting for the glue to dry.
ID:	2034864   Click image for larger version
Old 10-20-2014, 06:12 PM
  #100
jofunk
It has been a slow go but here is a little progress. Vladimir machined 4 plug ins that will connect the nose to the main body of the fuse. He also laid up some composite 7A bulkheads to set the machined plugs into. The break is just in front of the nose gear. It needs to come apart to make the fuse more reasonable for transportation. When the nose is off the main section of the fuse will sit on all three gear.
ID:	2041393   Click image for larger version
