Reload this Page >
Turbinator (V2) Thread
Old 11-16-2017, 11:27 AM
  #76
smoknrv4
smoknrv4's Avatar
Originally Posted by George
The next job was control horns which are completely different than the original, but this job was made easier with pre-cut slots. All were perfect except one set which were just slightly off, but nothing a dremel couldn't take care of. I don't have any pics of the actually step, but have pics showing the finished product with linkages and wires installed.
I'm building a Ziroli version, where can I buy this style control horns?Thanks!
Old 11-16-2017, 03:52 PM
  #77
rcmigpilot
My Feedback: (26)
Have you contacted Larry at Boomerang Jets to see if he will sell you a set?
Old 11-16-2017, 03:59 PM
  #78
smoknrv4
smoknrv4's Avatar
No haven’t tried that. I will do that.
thanks
Old 11-22-2017, 01:14 PM
  #79
horsefeetky
george what controller is in use for the brakes.........do they work well being electric......
Old 05-09-2018, 01:34 AM
  #80
TPerk
Hi guys, can any one tell me what power level you use on your landings? I seem to be keeping the power up to much on my landings, I was told to keep the power at about 1/3 throttle on landing and I keep land to fast and damaging my landing gear. Should I bring the throttle down to idle after I have turned on to my final approach with 45 degrees of flap? I am censored that I will stall it out if I do that, does any one know how well the Turbinator glide if I take all the power out after I turn on to final approach. What power level do you guys use on landing? Any input will be appreciated.
T Perk
Old 05-09-2018, 08:33 AM
  #81
CARS II
My Feedback: (7)
CARS II's Avatar
Mine has not flown yet but, with any airplane you have to experiment what it needs on final to make the runway the way you want it.
Flying my Boomerang on a no wind condition day I can throttle back to idle the moment it turns to the base leg, on a windy day I got to keep power to half till it turns final and my approaches are much shorter and higher to compensate for the head winds, if I fly the approach the same way as on a no wind condition day then I will have to drag the jet low and slow longer than I prefer, it is all about how you feel comfortable doing the landings.
I suggest to go up high and throttle back to a 1/4 throttle and fly the jet that way, if it doesn't hold altitude then allow it to descend doing circles over the runway, climb up high again and do the same thing again till you fell comfortable with it, that should help you get the feeling of it during slow flights, on windy day make a shorter approach, be prepare for go arounds.
I hope this helps, have fun, be safe
Old 05-09-2018, 10:19 AM
  #82
TPerk
Thank you, Cars II. I will try that out on Friday, it looks lake we will have a 7mph wind. I will use about 1/4 throttle till I get close to the runway and take all of the power out.
Old 05-09-2018, 11:10 AM
  #83
CARS II
My Feedback: (7)
CARS II's Avatar
If you feel comfortable cut the throttle around 25m before you get to the begining of the runway and keep descending, ground effect will give you a bit of extra lift when the jet is over the runway low and slow.
BE PREPARED !!! To go around early if you don't like the approach,.
No stress hey? Have fun and please report back
Old 05-09-2018, 07:28 PM
  #84
rcmigpilot
My Feedback: (26)
I've got an original 19lb Jet Central Rabbit in mine. Normal landing is turn upwind and drop the gear after the turn. If all three are down, I turn cross wind at about half runway, and pull the first notch of flap as soon as I'm straight on the down wind. I cut to idle then turn base, then final descending in the turns. Once on final I increase to 1/3 throttle and drop second notch of flaps. Once I know I've made the runway I pull the power back to idle and let the plane settle in.
Old 05-10-2018, 03:33 AM
  #85
TPerk
This is what I have been doing when I set up for a, landing, I do a gear check fly by down the field, then do a turn on down wind leg at 1/2 throttle and drip the flaps at 20 degrees then reduce throttle to 1/3 and then do a descending turn on final approach and then when I am lined up with the runway I drop flaps to 45 degrees and I am still at 1/3 throttle witch should be about 9lb. of thrust, then when I am close to the runway start reducing throttle to idle and I am still coming in way to fast and running out of runway. I have a King Tech 120 that has 27lb of thrust and the engine is set up at a half expo, this is the default on this engine and even at 1/4 throttle the engine is putting out about 16 % of the engines thrust witch is about 7 lb. of thrust. I was told to keep the throttle at 1/3 power, I think this is way to much throttle with this engine, now this is my first jet and I am taking others peoples advice. I hope this gives you some insight on my landings. I hope I am not taking up to much of every ones time on here. I also would like to know what you guys are doing on a missed approach to do on your go around, do you take out all of your flap or do you just take out 1/2 of your flap. Do you power up first and then take out some or all of your flap.
Again, thanks guys.
T Perk
Old 05-10-2018, 06:17 AM
  #86
Vincent
My Feedback: (61)
Vincent's Avatar
T Perk...a friend of mine has the KT 120 in his Excalibur and it won’t slow down with that motor either. He has lowered the idle rpm by about 4K and turned out both rudders for more drag and it’s still a challenge. The plane will roll by itself even on his reduced idle. It’s too much motor for the turbinator. I have a Jetcat P70 in mine and it flys great but a 100 size motor would be perfect.
Old 05-10-2018, 07:59 AM
  #87
CARS II
My Feedback: (7)
CARS II's Avatar
What Vincent said is correct, you have a much bigger engine than needed, since you are getting more residual thrust then the usual, then cut the throttle on the base turn and go from there.
For the go around, throttle first, for flaps and gear, you have choices, 1 leave all as is, fly the airplane to enter the pattern to land again but don't allow the jet to accelerate to much by reducing thrust as soon as you have gained altitude, 2 flaps up one notch and climb to pattern altitude, again don't allow the jet to accelerate, throttle back when the jet is at pattern altitude, 3 move everything up, flaps first gear second and throttle back.
What I do if I have to do a go around is, throttle to max thrust, fly the airplane as it gains altitude, once it has gain altitude then I reduce the throttle to about half and I bring her around for another landing, I don't touch the flaps or gear, the one thing I don't allow is for the jet to gain too much speed in that configuration, practice, practice, practice, don't be too concern about go arounds, they are your friends and save you from making a bad landing, make a flight all about emergencies and go arounds, to get familiar with the glide envelop of your jet.
Have fun.
Old 05-10-2018, 09:07 AM
  #88
Vincent
My Feedback: (61)
Vincent's Avatar
One other way is to make a very tight down wind off the edge of the runway and then a sharpe turn on final and you are down. Sort of a carrier type landing. A long normal glide approach going to idle farther out will work too but that will take some getting used too. Be prepared to get on the throttle just in case you get a sinker and come up short. A head wind is always nice but in dead air my buddy has also killed the motor completely on final. Not a great way to land but that works too.
Old 05-10-2018, 10:02 AM
  #89
grbaker
My Feedback: (29)
grbaker's Avatar
I would try to use more than 45 deg of flap (all you can get) and add some crow, if you haven't already.
Old 05-10-2018, 10:41 AM
  #90
CARS II
My Feedback: (7)
CARS II's Avatar
Definitely crow will help big time here.
Old 05-14-2018, 04:26 PM
  #91
GSR
My Feedback: (145)
I replaced the thick aluminum bottom skin with some 19/1000 aluminum. it is plenty strong and saves 5 oz of tail weight over the stock part. S
Old 05-14-2018, 04:32 PM
  #92
horsefeetky
i own the one george built for the review when at dreamworks and it has the same alum skin on the tail also
Old 05-15-2018, 06:31 AM
  #93
Vincent
My Feedback: (61)
Vincent's Avatar
nice idea Scotty the plane does come out tail heavy that is a big weight savings in the tail.
Vin...
Old 05-16-2018, 06:12 AM
  #94
smoknrv4
smoknrv4's Avatar
Where to buy this aluminum, (19/1000)?? I'm at that stage in my build and am wondering what to use!
Old 05-16-2018, 06:37 AM
  #95
horsefeetky
I have used litho plate from printing companies they only use one side then dispose. Check in with local print shops or newspapers if any still exists
Old 05-16-2018, 06:54 AM
  #96
GSR
My Feedback: (145)
Home Depot. $9.00
Old 05-16-2018, 06:57 AM
  #97
smoknrv4
smoknrv4's Avatar
Home Depot. $9.00
What am I looking for at Home Depot?? Whats it called? Thanks
Old 05-16-2018, 09:13 AM
  #98
CARS II
My Feedback: (7)
CARS II's Avatar
I saw this at the HD the other day, it maybe it, not sure.
Old 05-16-2018, 10:37 AM
  #99
GSR
My Feedback: (145)
It is in the stock sheet metals rack the sheet is 22" by 12" -Use the original for a pattern (you can also make it a few mms bigger for a better fit. Just cut it with shears or an old pair of scissors
Old 05-16-2018, 11:56 AM
  #100
smoknrv4
smoknrv4's Avatar
Thanks Guys! I'm a breath away from finishing my Ziroli build!
