Composite ARF Mig29
#376
My Migs nose gear collapsed twice during taxi tests filling the cockpit with hydraulic oil, took a lot of work to get it right. On the Mig 29 as you know there is so much weight on the nose gear as its right back under the cockpit. I also cut the springs in the mains to lower the rear height as it had a negative A of A. This also relieves the nose of a little weight too and helps with rotation.
#377
I did not bother with ailerons, just the taileron as per the original, still handles really well with nice roll rate. Used max travel possible for both pitch and roll. As Levi has found twin JetCat 140s give excellent performance.
I explained the the technique for dealing with an engine failure just after lift off in last RCJI, it handled it really well with those big fins. On reflection it could probably have coped with even more power than I used if the speed is kept up and rudder is fed in as soon as the failure is recognized.
Really like those exhaust nozzles of Campano.
Great flying machine!
David.
David.
#379
last top gun i flew my mig29, from take off to landing with just one engine, a jetcentral rabbit, 10 kg.
this machine is really incredible, light, and no problem to fly with one engine,
gus
gus
#380
Here is my Mig up close Chris. I got mine half built from a friend here in OZ. He had done a brilliant job solving some of the issues with the kit already but i still had my work cut out finishing her off. I finished the build then painted and weathered it myself. Its an ongoing project with some more details yet to add. If you need any more photos let me know i got heaps.
Levi
#381
Awesome thanks for the pics Levi, great looking jet for sure.
Im curious about the main gear. I've seen a couple of these jets now with the main gear looking like it's spreading out. It's supposed to be vertical. Is there a problem with the mounts or something twisting in the fuse?
#382
#383
Strut angle is critical to ensure correct retraction.
My Mig is currently grounded as the main struts have bent outwards on the last landing, which was perfectly smooth.
I have new struts to replace them, not fitted yet, and I will let you know what I find when I fit them.
Perhaps the the early struts were made of softer material than the later ones.
David.
David.
#384
I solve the problem to mount main paralel legs. There are one possibility.
You has to start mounting a piano wire inside the axle hole on mains gears, cross both mains, after that's mount the legs on the main landing fuse mount, mounting the system to the fuselage with epoxy, the epoxy will absorve the difference between the fuse mount and the correct position.... Sorry my English. The point is.... Fuse main plywood mount are not correct....
#386
The problem was the arc that the leg swings on during retraction won't clear the fuse if vertical. Have you fixed yours yet and do you have a pic of what you've done?
Thanks Gus
Levi
#387
MI
Landing Gear Question
My Mig is kit 18 and was complete with the early hydraulic system including the cylinders without locks. I missed out on getting an updated set from CARF. Is there any simple method to mechanically hold the gear in the down position while the model is on the work bench. It would make it easier to work on if I could keep it on its feet. Can I buy the locking cylinders anywhere? I've sent emails to Hausi but didn't get any replies. I suspect a phone call would be better.
John
John
#388
Hemi,
During my build I removed the cylinders and installed steel rods of the right lenght. A round of locking wire will keep the cylinders compressed too. No available info on the locking cylinders, sorry.
#389
The other option is to put a ball valve in between the nipples on the cylinders...open to change position of the leg and close it to lock them in place. Levi is right about the clearance issues with the main legs. I tried to get mine as close to vertical as I could but they are not perfect. Gus, your building suggestion is a good one thought for getting the legs aligned well. Will try that on my next one.
#391
#395
Forcing them may lead to a burst pipe and a mess. Been there done that !
I dont think the the real Mig has truly vertical legs, mine does not.
I am not at home at the moment but will check angles on return.
David.
#397
Yes, Per, I make that about 1.5 degrees angled out with wheels virtually parallel to struts so slightly cambered. ! It's about where my Mig was, before the struts bent. It was achieved on my kit without adjustment !
#400
ok, one by one,
i m using on my old composite arf kit, and add some valves from HP-Tech Pumpen für Modellbau und UAV's and work perfect. must to add some valves at the cilinders....
about my mig main legs and wheel....work perfect. and fit perfect inside the fuse. really i spent weeks to find the perfect point, to find it, i had to open the 3 holes on the aluminum mounts at plywood fuse,
and make with smalls plywoods spacers..... as i told you, i used a carbon fiber 6mm tube crossing wheels axle, (be sure the legs has smalls screws so you can disasembled complete ,up down, spring. sicsors...
patience.......
check both legs must be paralel and like 4 o 5 degres to front.......
mount the aluminum mounts to the leg with some soft adhesive or tape or rubber bands... to keep legs and aluminum togheters.... now you has both legs parales with the carbon tube in betwens axle hole, slowly fit the aluminum mounts to plywood fuselage, and check holes with holes on plywood.... slow.... and check where you need to add some plywood ( 0.5 to 1 mm). you will find.....
as soon you arrive, fit at least one screw on each aluminum.
NOW... if you has this step done.... now you has to check if the wheels fit in the fuse..... for thats..... take out the carbon fiber tube , add the axles in each leg. slowwwww.... remember you has one screw and small plywood betwen plywood and alumiunm leg base......
as soon work..... add 5 minute epoxy with charge .. betwen the aluminm base and the plywood.......
add more screw..... done.......
sorry my englishouthamerican....... i hope you understand......
tomorrow will send photos about my work
patience.......
