Composite ARF Mig29
#426
No ailerons, mine are fixed.
Should have the A700 servos soon.
David.
#427
Two of the new Futaba HPS a 700 servos have arrived and will be fitted into the Mig next week, so thanks for the heads up about these Futaba servos, Craig.
With 70kg/cm s of torque I guess these servos are going to be the ultimate for flutter resistance and accuracy under load.
As as soon as they are fitted and the linkage reviewed to absolutely ensure the tightest control circuit It will be airborne again. That said, I may still completely review the stab mount and control installation as per Craig’s design, looks like a winter job though!
I will I’ll be doing a review for the A700s for RCJI similar to that which I did for the superb Ditex servos. ( Fantastic servos but the Futaba is over twice as powerful. )
David.
David.
#428
Hi All
I now its an old thread but need some advise. I just got hold of a mig 29. Its been in storage for a couple of years so need some tlc. I have no manual or any instructions. Model was built with ailerons fixed .Nee throws and cg position. What size turbines best suited.
Thanks Alex
Thanks Alex
#429
I would suggest you go through this whole thread. There is a lot of experience related in it which I am sure you will find very useful and save you a lot of hassle. All of your questions will be answered in detail.
David.
David.
#435
My Feedback: (44)
IL
Hello there , I decided to go back on these jet and work a little bit on the Ailerons and flaps so I’m posting some pictures of the progress my flaps were ripped all the way through so I had to use some Kevlar and it work with no issues.
#438
My Feedback: (44)
IL
Does anybody know the flight time with the kingtech 140s I have the original fuel tanks. I am ready for the maiden flight if the weather gets better I’m might do it next weekend here are some more pictures .
#444
Looks fantastic spaceman. I really like that scheme. Mine is almost done. Here is a short vid of my gear test. I have to adjust the timing in the doors but that should be straight forwards. 2 cylinders on the nose retract. Locking cylinders on all 3 gear.
#445
Hi Nick,
Levi will no doubt let you know what his flight times are. He has the original tank’s and Jetcat 140s in his mig. Almost midnight at his place now but he will chime in tomorrow I guess.
#446
Nick, my Mig has jetcat 140 engines and I set the timer for 6 minutes which allows ample reserves for a couple of go arounds. You may be able to add a couple of minutes with experience.
The Mig flies beautifully with tailerons so do let us know how it goes with ailerons.
Nice paint scheme and good luck with flying.
Craig, your gear looks perfect, please advise pump/ battery combo as it’s faster than my setup.
Mine me will be flying again soon with the superb Futaba servos you recommended.
Thanks for the tip !
D.
ps you guys might be advised to glue the tyres to the wheel hubs. The original tyres expand with centrifugal force and almost leave the hubs.
#447
My Feedback: (10)
https://youtu.be/x5DyfXYEmes
#449
My Feedback: (44)
IL
David, thank you I will do the first flight set at five minutes. the kingtech engines tend of sucking a bit more fuel. I am looking of doing the test flight this coming weekend if it does not snow here in Chicago.
