Composite ARF Mig29
#151
MI
RE: Composite ARF Mig29
Craig
The cable attaches to the piston operating rod by looping it through the hole you have to drill in the flattened tube that was soldered on the rod. Next the cable runs forward in fuse and gets looped over a dowel rod epoxied in the fuse. You can see the dowel on the second picture. The cable then head back towards the tail and exits the tail right next to the plastic tube that the servo operating rod passes through. You have to have someone help you compress the chute piston and create another loop like you did on the other end of the cable. With the servo arm pulling the release rod back you have to slip the loop into the furthest 2mm slot cut in the chute tube. When the servo moves the rod forward the rod captured the release loop and keeps tension on the piston.
Note the chute is attached in the same manner but in the second 2mm slot cut in the tube. The idea is the servo should be set to have two movements. The first moves the rod enough to release the piston tension cable. This is suppose to allow the piston to be release and pop the chute. The door is held close just by tension on the hinge. The 2nd movement of the servo pulls the release rod back past the second slot, this allow the chute to be separated from the plane. I saw Klurh release the chute while he was taxing back at Superman. I'm not sure why unless he was concerned about the heat or something like that.
I agree the instructions are poor. I don't quite have mine working but from what I can tell this is how it's supposed to work. I do not have the rudder servo's installed yet so I can't help. I have installed the carbon tubes and rods so I can put them on my plane.
Hope this helps
Hope this helps
#152
HI John,
Great explanation...thank you! I now understand how it is supposed to work and how to set it up. I wonder if the small piece of plastic tubing between the slots would best be held in place with some carbon roving rather than the aluminium strip as that section will be under quite a bit of load.
Thanks for you help. Time to press on!
Kind regards,
Craig.
ps. Ro, where you at dude?
Kind regards,
Craig.
#153
MI
Craig
That's a good idea. I may change mine. The manual that comes with this plane needs a lot of work. Ro is doing such a nice job documenting his build and inspired me to get back to work on mine. I figure the more pictures the better so we can help each other. So jump in and take pictures and post them. Its a complex build and everything takes loner than I thought it would but it's very enjoyable work for me.
Take care
Take care
#154
Hey Guys,
I'm in the process of packing up all my things as I will be moving very soon!
Looking forward to seeing what you guys are up to on the thread though. I Hope to be back on it when I setup shop again!
I hear there are no more mig29's left at CompArf. They must have hit 100 now. I think mine was 96
chat soon guys,
Ro
chat soon guys,
Ro
#156
MI
Thomas
Don't worry about jumping in. If your building one, join in. I'm not sure, mine is kit 18 and has the original gear and hydraulics so I can't help. Are you going to try to use air operated landing gear?
Best regards
Best regards
#157
MI
Ro
Are you moving to Germany? I wish you the best with your move, be sure to pack the Mig well and try not to lose any parts. If you need any one to guard and protect your exterior accessory kit that I haven't been able to get yet, I'll guard and protect it for you with my life. Of course I would store in a perfect place. On my Mig. HA HA.
Best of luck bud, stay in touch.
#158
My Feedback: (23)
ORIGINAL: hemi
Thomas
Best regards
Thomas
Best regards
John,
actually i can only wish i had a Carf Mig 29. beautiful looking model. Actually i'm looking at using the hausl system for the landing gear, speed brakes, slats and canopy on a scratch built 1/7 F-14 i'm working on. I went on the hausl site, and it said that the actuators are "custom" made, but was wondering if the ultra-precision cylinders and the like could be used with the hausl system as well.
#159
MI
Thomas
Good luck with your project. You might contact my friend John at Matrix Machine, he has a nice website and he loves F14's. He makes 1/10 scale gear and might be able to offer some advice. I saw an old Jet Age F14 along time ago and it was 1/7 scale. That's a big cat your building there.
Best regards
Best regards
#160
My Feedback: (23)
ORIGINAL: hemi
Thomas
Best regards
Thomas
Best regards
John,
thats who i'm planning on getting the landing gear from...
anyone have any idea on the actuators?
#161
MI
I've got no experience with them. I know Ro has the updated gear on his Mig and its sits on its gear and the hydraulics are not installed yet. Maybe he used air to lock the cylinder in the down position.
Ro, whats your thoughts.
Best regards
Best regards
#162
My Feedback: (10)
ORIGINAL: invertmast
I got actuators from Peter, they are quite nice and he is very nice to deal with, very professional.
As for any other cylinder, it should work if the materials are not sensitive to the oil you plan to use.
And of course you have to watch the pressure, 8 or 9 bar is a lot.
#163
My Feedback: (23)
ORIGINAL: mr_matt
guess their is really only one way to find out then.. Per my math 8 or 9 bar = 117.6 to 132.3 psi. What fluid is used for the hydraulic fluid, i though i saw it mentioned someplace that it was just normal automotive automatic transmission fluid?
#164
MI
Everything I've read on the Mig gear says any good hydraulic fluid like ATF or power steering fluid works fine. The retrofit instructions for updating the original Mig gears says that one well known Mig flyer uses baby oil. I was going to use ATF in mine so it would be easier to see any leaks.
Best regards
Best regards
#165
My Feedback: (23)
ORIGINAL: hemi
Best regards
Best regards
ok, thanks for the help, i've got an UP cylinder or 2 laying around that i can play around with to see how it holds up to ATF fluid and the like. I dont perceive it being a problem though.
#166
HI guys,
I am wondering if there is any problem using silicone shock oil as is used in rc car applications for the mig hydraulics. Any comments guys?
Craig.
Craig.
#167
sorry to butt in guys, but can anyone tell me if the hausl hydraulic system has to use hydraulic specific actuators, or can you use air cylinders with it?
thanks
thomas
thanks
thomas
The latest L/G cylinders have internal locks fur the extended and retracted throws.
Cheers,
Ro
#168
ORIGINAL: hemi
Ro
Ro
Hey John,
Yes, moving to Germany. Its such a beautiful place. I dont know of any flying fields in or around Frankfurt?
LOL!! Nice one !! I will try and get in contact with the source for those accessories for you when I move. Re-packing the mig29 will be a task I'm sure. If anyone out there still has theirs in the box take some picture and post it for ref!
Cheers,
Ro
#169
ORIGINAL: hemi
Best regards
Best regards
to lock and unlock the cylinders you just need to use syringe with a 4mm hose on the end to apply the needed pressure to unlock or lock the valve.
In regards to using air cylinders. I have not tried it personally but if air does not leak then why would oil right. a simple test rig will answer this im sure.
Ro
#170
ORIGINAL: Craig B.
HI guys,
Craig.
HI guys,
Craig.
If not using hydraulic fluid I would only use baby oil as it is mineral oil. The silicone used in the rc car shocks is very thick and will not be something you would want to use in a hydraulic system.
I'm no pro at any of this stuff but just my 2c mate.
Ro
#171
ORIGINAL: hemi
Best regards
Best regards
I painted parts of the interior airframe with a thin coat of primer to help with spotting leaks faster. I may also try adding dye to the baby oil to see if that works
#172
MI
Ro
I've been working some other projects here at home but I'm looking forward to getting back on the Mig. When's the big move? Are you going to be doing the same kind of work in Germany? That would be awesome if you could locate me a set of accessories after you get settled in. I would think baby oil would work great and if you get the scented oil you could sniff out the leaks. Stay in touch my friend.
Best regards
Best regards
#173
Hey Craig,
Actually, the car shock oil comes in a whole range of weights/viscosities and the lower weight stuff is very low viscosity.....less than the hydraulic fluid. I am wondering what sort of seals these cylinders have as that is the main determinant of what type of oil you can run. If they are standard O-rings, I would not be using anything that is mineral oil based as it will dissolve the O-rings eventually. Silicone oil would be safe to use on the other hand.
I must stress that I am no hydraulics expert but I have about 15 rc cars so I know a little when it comes to shock oil .
Craig.
#174
My Feedback: (23)
ORIGINAL: Craig B.
Hey Craig,
#175
MI
David Gladwin
David are you out there. We have a little discussion going on here onwhats the best hydraulic fluid to use in the Migs. Since you have the most experience with the Mig's hydraulics can you you offer any suggestions on whats a good hydraulic fluid to use?
Best regards
Best regards
