TF FW190 GIANT ARF
#4529
The small variation from accurate dihedral to what Top Flight turned out in this arf, would not cause any quality of handling issues in a plane of this type. It's not a pattern or 3D plane.
EDIT,
Dang Bobh, your on the same channel Im tuned to
EDIT,
#4533
The Sierra gear will hold up, even at the wrong dihedral. The wheels have a lot of strain on them though. You'll need wheels with good bearings, or they will not hold up due to the the angle caused by the incorrect dihedral.
If it was me, I'd correct the dihedral when I install Sierra gear. It looks much more scale, and from all accounts the flight performance is just as good. Ground handling will surely be better, and that's where you can always use some help on this plane.
#4534
#4535
The only RC wheels with bearings that I know of is "Air-Man Wheels".
https://www.airmanwheels.com/collect...ith-3-16-axles
Roger
Roger
#4536
I got some 1/4 internal dimension bearings and inserted them into the wheels I had. Other than that, you almost have to use aluminum wheels that have good brass bushings or bearings. Regular plastic wheels will not hold up under the side loads that the wheel angle causes when you use Sierra gear with the incorrect dihedral. I used some needle bearings that look like this. They are not as large OD as standard ball bearings.
#4537
Do you think that the fg60 r3 will haul this plane around here in the Rockies at 5500 to 7300 ft elevation?
Thanx
Dan
#4538
While I'm sure it would fly the plane at that elevation. I'm also sure it would not be as good in performance as it is at seal level. Especially on a high temperature day that would push your density altitude WAY above 12000' in a hearbeat.
I'd suggest at least the FG90R3 in your case.
#4539
Dan
#4540
Just remember to fly it on the wing and not the engine.
Use LIFT and airspeed, not brute force to make it go where you want.
Remember that the thin air not only robs your engine of power, but lift from your wings.
Good luck
Good luck
#4543
But as to how much power it will have to allow you to enjoy the aerobatics type flying I was doing at sea level, well, I'd rather go up in size to the FG90R3. Especially if the days get hot and muggy.
Thinner air kills power and lift.
There is a reason why they put forced induction on full scale aircraft piston engines. Since our selection of engines with forced induction, turbo or supercharging are limited for models, just increase the displacement.
#4544
I understand what you're saying.
Honesty though, since I fly here at altitude(5300'), I can relay this...
I had an 89" Spitfire flying on a turnigy 50cc Gasser. It flew exceptionally well on a 20x10 prop. That turnigy 50cc is not nearly as powerful as a DLE or DA of same displacement.
The spitfire weighed 27.5 pounds.
I can't imagine an fg60 is going to have a problem here. If it can swing a 22x10 @ 6500 .....thats the same rpms I was seeing the turnigy motor swinging a smaller 20x10 on a similar size and weight plane.
Will it perform here the same as at sea level? No... there will be a difference yes, but not that great of one.
An fg90 would sure be a great motor for the 190 here for sure, but the fg60 will perform quite well also.
Personal choice of the builder... Having options is a great thing.
#4546
FL
Balance point on the Top-Flite FW-19+0
Are you sure the balance point is one and a half inch behind the recommended 5 &1/2 inch from the front wing former . I would like to take some lead out to make the plane lighter .
#4547
Yes, I am sure.
It flies much better, balanced as I have it as compared to the suggested point from the instructions.
Do NOT go aft of that point as I have no experience with anything other that what I've stated in this thread.
#4550
I don't have the dimensions here with me at work.
It sounds like you and I are on the same track.
I find the mean aerodynamic chord and then go back 28% to 33% depending on the plane.
