Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 08-03-2012, 05:11 PM
  #51
n8622t
My Feedback: (8)
Default RE: TF FW190 GIANT ARF
I have the electrics ordered for the FW190 and called Robart today. They told me that the P-40 electrics will be out in about one week to order from Tower...just knowing that they are built by Down And Locked is enough for me, Im definitely on board
Old 08-03-2012, 06:15 PM
  #52
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Well, Consider that you're dealing with a short nosed bird. I'm thinking something with some weight like a Zenoah something.[:-]
Old 08-03-2012, 08:24 PM
  #53
Hellcat716
Hellcat716's Avatar
No. I bought the gear when I first ordered the plane last December. It is a pnuematic system, working well.
Old 08-04-2012, 05:58 AM
  #54
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
What's the link for the robart retracts?
Old 08-04-2012, 09:41 AM
  #55
n8622t
My Feedback: (8)
ORIGINAL: Ramstein44
http://www3.towerhobbies.com/cgi-bin...?&I=LXCHVL&P=7
Electrics
Old 08-04-2012, 09:43 AM
  #56
n8622t
My Feedback: (8)
http://www3.towerhobbies.com/cgi-bin...?&I=LXCHVN&P=7
pneumatics
Old 08-04-2012, 09:46 AM
  #57
n8622t
My Feedback: (8)
ORIGINAL: Hellcat716
I have had great luck with all of Robarts pneumatic stuff...actually better luck than with any other mfg. I think the Down and Locked combo is going to be as good
Jimmy
Old 08-04-2012, 05:44 PM
  #58
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
ORIGINAL: n8622t
Electrics
Thanks.
Old 08-05-2012, 04:43 PM
  #59
jeffk464
Maybe go larger and grab some speed.
Old 08-08-2012, 06:48 AM
  #60
tfarmer96
tfarmer96's Avatar
ORIGINAL: jeffk464
Sounds like a DA85 kind of thing....
Old 08-08-2012, 01:43 PM
  #61
n8622t
My Feedback: (8)
Here is some info on the cowl... TF rep said the DLE55 head fits entirely in side the cowl with plug cap out, the DLE55 head is 123mm so the cowl is at least 246mm in diameter.... Sounds like a DA85 to me
Jimmy
Old 08-08-2012, 02:53 PM
  #62
dasintex
My Feedback: (10)
dasintex's Avatar
I wonder which DLE55 the TF Rep is referring to, he may be referring to the older style DLE55; the new Rear Exhaust Style DLE55 has the plug angled towards the rear as well, and the new style DLE55 including Spark Plug Cap/Boot, may fit completely inside the cowl.
Old 08-08-2012, 09:44 PM
  #63
jeffk464
ORIGINAL: tfarmer96
ORIGINAL: jeffk464
I wonder what kind of speed that would give
Old 08-08-2012, 10:37 PM
  #64
P47Pilot
ORIGINAL: tfarmer96
Tfarmer, I know that you have used the DA85 on other TF GS planes of the same size, such as the P-47. How many flights do you typically have on them with this engine?
Cheers
P47Pilot
Old 08-19-2012, 06:21 AM
  #65
ENO
Live from Fondulac Warbirds over the midwest demo...
ID:	1793259   Click image for larger version
ID:	1793260   Click image for larger version
Old 08-19-2012, 07:30 PM
  #66
kahloq
kahloq's Avatar
Nice looks like it could be easily electrified with easy battery access with that gun hood area hatch.
Old 08-20-2012, 08:49 AM
  #67
paladin
My Feedback: (9)
kahloq, what motor/ battery combo though?
looks like electric could be expencive?
Joe
Old 08-20-2012, 11:58 AM
  #68
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
I pulled these off another thread here. More detailed pictures would be nice.
http://www.rcuniverse.com/forum/m_11197406/tm.htm
ID:	1793585   Click image for larger version
Old 08-20-2012, 01:12 PM
  #69
tp777fo
My Feedback: (28)
tp777fo's Avatar
Just ordered mine with retracts. Didnt order a motor yet as I want to take a good look and see how big the cowl is. Want to fit something that will turn a nice 3 blade prop.
Old 08-20-2012, 01:26 PM
  #70
wulf190
My Feedback: (19)
wulf190's Avatar
I can help some Charles. I combed over it as much as I could. It has a DLE 55 for power, and flight is VERY impressive. I've never bought an ARF, but this one is a winner. Construction looks good as does scale outline. The Robart gear have the cylinder placed behind the axle pivot, so this might make dropping in Sierras more complicated...but the Robart gear looked good. It flew a little "lighter" than the Holman, but did everything that the Holman version does well, just as good....awesome cornering, good ground handling, stable landing approach, etc.. I think he said the weight was around 23lbs, so with the DLE it's a lively performer. An ARC might be forthcoming if enough people email TF for it...so if you want one in ARC, ask and maybe down the road it will happen. The finish on the ARF is ok if you're alright with covering and stuff, but personally I would strip it. If it were glassed and detailed after purchase it could look fantastic. The cowl is panel lined, but not the plane. You will be extremely pleased with it. I would have no regrets buying one.
Old 08-20-2012, 01:32 PM
  #71
wulf190
My Feedback: (19)
wulf190's Avatar
Here's some others...
ID:	1793616   Click image for larger version
ID:	1793617   Click image for larger version
ID:	1793618   Click image for larger version
ID:	1793619   Click image for larger version
ID:	1793620   Click image for larger version
ID:	1793621   Click image for larger version
Old 08-20-2012, 01:41 PM
  #72
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
ORIGINAL: wulf190
I can help some Charles. I combed over it as much as I could. It has a DLE 55 for power, and flight is VERY impressive. I've never bought an ARF, but this one is a winner. Construction looks good as does scale outline. The Robart gear have the cylinder placed behind the axle pivot, so this might make dropping in Sierras more complicated...but the Robart gear looked good. It flew a little ''lighter'' than the Holman, but did everything that the Holman version does well, just as good....awesome cornering, good ground handling, stable landing approach, etc.. I think he said the weight was around 23lbs, so with the DLE it's a lively performer. An ARC might be forthcoming if enough people email TF for it...so if you want one in ARC, ask and maybe down the road it will happen. The finish on the ARF is ok if you're alright with covering and stuff, but personally I would strip it. If it were glassed and detailed after purchase it could look fantastic. The cowl is panel lined, but not the plane. You will be extremely pleased with it. I would have no regrets buying one.
You rock!!
Old 08-20-2012, 01:50 PM
  #73
wulf190
My Feedback: (19)
wulf190's Avatar
Maybe not so much really. I was mightily impressed by it. They really did a great job with it. There's no way you could build a kit to ARC condition at the price they are charging for this....maybe if you cut your own, but even then...I doubt it. The only reason I probably won't get one is that I already have two Holmans and never fly much anyway...but it's good, trust me. Any of you guys getting it are going to be REALLY pleased with your purchase.
I would add that something would need to be done to the t.w. retract. It has a stock 160 type retract in it and it needs something more in tune for both scale fidelity in the up and down position and function in terms of getting the tail off the grass more. This isn't a big deal probably, but I have no idea how installing a scale t.w. retract in there would go...just something to consider.
Old 08-20-2012, 01:57 PM
  #74
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
I'm on the list for the Pneumatic gear. I kind of thought after mentioning going with Sierra gear, the complications of their installation. It could be done if you ripped the retracts ribs out and customized the area but I complicate these enough as it is!
Old 08-20-2012, 01:59 PM
  #75
dasintex
My Feedback: (10)
dasintex's Avatar
ORIGINAL: wulf190
Thanks for the report. I'm guessing it had the older/current DLE55, not the new DLE55RA with rear exhaust, due for release in September! I wonder which one would fit it better, seems like the new style would?
ID:	1793644   Click image for larger version
