Reload this Page >
CY MODELS La-7//Evolution 160 radial
Old 10-13-2017, 08:50 AM
  #301
n8622t
My Feedback: (8)
Originally Posted by BobH
All that hard work is paying off, good job.
thanks BobH....just took a short break but now I'm back to it. I'll post some pics when I get something done
Old 10-14-2017, 02:46 PM
  #302
n8622t
My Feedback: (8)
I was glad to see it go on in one coat!!!
ID:	2241217   Click image for larger version
ID:	2241218   Click image for larger version
ID:	2241219   Click image for larger version
Old 10-14-2017, 05:41 PM
  #303
BobH
One Coat??? I'm never so lucky!! Good job.
Old 10-15-2017, 05:05 AM
  #304
n8622t
My Feedback: (8)
I went back out last night and pulled all the tape and masking off....that was my first time using latex paint and it went on really well.
Old 10-15-2017, 05:07 AM
  #305
n8622t
My Feedback: (8)
Thanks BobH, Ill be headed back out to the shop this morning and take a few pics to post. Latex is sure easy to clean up after the job
Old 10-15-2017, 05:39 AM
  #306
BobH
Jimmy,
I like using Latex too. It sprays nicely and cleans up super easy. It does have to "cure" for some time at least a few weeks.
I also clear over it with minwax ploy satin clear for protection.
Old 10-15-2017, 07:08 AM
  #307
n8622t
My Feedback: (8)
Today is clean up day😜
ID:	2241275   Click image for larger version
Old 10-15-2017, 07:11 AM
  #308
n8622t
My Feedback: (8)
Jimmy,
thanks BobH. Is the minwax fuel proof?
Old 10-15-2017, 06:15 PM
  #309
n8622t
My Feedback: (8)
Paint booth cleaned up and heater turned on...let the heat cure the paint for a couple of days then assemble the wings
ID:	2241311   Click image for larger version
ID:	2241312   Click image for larger version
Old 10-17-2017, 06:00 AM
  #310
n8622t
My Feedback: (8)
Assembly time😃
Old 10-17-2017, 10:13 AM
  #311
n8622t
My Feedback: (8)
Finish this gear then glue the hinges....that will finish the right side
ID:	2241468   Click image for larger version
ID:	2241469   Click image for larger version
ID:	2241470   Click image for larger version
Old 10-17-2017, 11:29 AM
  #312
n8622t
My Feedback: (8)
Air cylinder holds for hours
ID:	2241476   Click image for larger version
ID:	2241477   Click image for larger version
Old 10-17-2017, 12:10 PM
  #313
n8622t
My Feedback: (8)
Clean these up and glue in
Old 10-17-2017, 04:16 PM
  #314
n8622t
My Feedback: (8)
I'll hinge these tomorrow
ID:	2241485   Click image for larger version
Old 10-18-2017, 07:14 AM
  #315
n8622t
My Feedback: (8)
First of the trim work👍
ID:	2241548   Click image for larger version
Old 10-18-2017, 09:24 AM
  #316
n8622t
My Feedback: (8)
Guns go in next😃
ID:	2241571   Click image for larger version
Old 10-18-2017, 01:43 PM
  #317
n8622t
My Feedback: (8)
Got the sheet metal on the exhaust ports
Old 10-18-2017, 04:43 PM
  #318
n8622t
My Feedback: (8)
On to some hinging
Old 10-18-2017, 04:47 PM
  #319
n8622t
My Feedback: (8)
It took 25 minutes to hinge 2 ailerons 2 flaps 2 elevators and one switch hatch with no clean up required😜👍
ID:	2241598   Click image for larger version
ID:	2241599   Click image for larger version
ID:	2241600   Click image for larger version
ID:	2241601   Click image for larger version
Old 10-19-2017, 08:43 AM
  #320
n8622t
My Feedback: (8)
Getting the major parts assembled and fine tuned today....still waiting for paint masks👍
Old 10-19-2017, 02:11 PM
  #321
n8622t
My Feedback: (8)
Need paint masks then it's just a few final things, like hang the engine😜
ID:	2241669   Click image for larger version
ID:	2241670   Click image for larger version
Old 10-19-2017, 02:34 PM
  #322
n8622t
My Feedback: (8)
Got the gear all tested and works very well
ID:	2241672   Click image for larger version
ID:	2241673   Click image for larger version
Old 10-19-2017, 06:12 PM
  #323
n8622t
My Feedback: (8)
Tomorrow I'll hang the engine and balance it
ID:	2241682   Click image for larger version
Old 10-19-2017, 08:30 PM
  #324
warbird04
Hello Jimmy,
You make an incredible job on the La-7... continue so! The result is perfect, and i Wonder to see the maiden.
After balance and final assembly, give me please your final weight.
For me, the Lavotchkin will be ready this afternoon. I send you some details pictures about the result this week-end. The maiden will go next week, this time we have some rainy day...
In the german forum about the Cy Model La-7, i find an info about the deflection about the control surface:
- for elevators, +/- 6 cm at largest point.
- for ailerons +4.5 cm / -3.5 cm at point near the flaps.
- 25-35 % expo on elevator and aileron
- CG is confirmed at 195mm measured on fuselage side (as discussed previously)
See you soon.
Old 10-20-2017, 04:05 AM
  #325
n8622t
My Feedback: (8)
Originally Posted by warbird04
Hello Jimmy,
See you soon.
that is very good information warbird 👍 So the CG being used by others is the 195 mark which is the furthest mark back according to the manual recommendation. That will also help with the task of balancing since the moment to the planes tail is so long as compared to the nose moment.
Thanks warbird those measurements will be of great help
