Canopy dent repair
I guess you have already looked at asking for a replacement?
Try some real gentle heat on it (Hair Dryer) try to manipulate it back again.
Keep in mind the dent has the potential to stretch the canopy material, and a consequence is that the material is reluctant to go back to the original shape, however gentle heat, and a lot of patience will help.
The end of the day there is a lot of experience on here, someone may have a better idea.
You can try also to support on the bench your canopy.Before you can insert on it a simple ballon without air but ready to swell it.Then you will swell it until it takes the inside shape of canopy then you can heat the canopy with care on the point of dent. The ballon will force the heated canopy point to come back to original shape!!You can also must have ready one glass of water to catch a cold immediately and secure the shape.
