Welcome to Club SAITO !
Old 12-02-2007, 09:52 AM
  #9251
My Feedback: (16)
w8ye's Avatar
Default RE: Welcome to Club SAITO !
Put a little short piece of fuel line over the needle valve where it will push up against the needle valve body and seal the leak of the O ring.
Old 12-02-2007, 10:16 AM
  #9252
I'll try that. I run fuel pumps on most of my other engines and like the consistency. Hence I was thinking about installing one on the 72 and was wondering if Saito's fuel pump (the one that operates off of crank case pressure) would work on it. Has anyone tried this?
Old 12-02-2007, 12:53 PM
  #9253
My Feedback: (16)
w8ye's Avatar
That Saito fuel pump is one of the most aggravating things known to man.
You can never get the pressure just right.
It's best use would be to pressurize the tank and then use a Iron Bay or Cline regulator.
Old 12-02-2007, 03:54 PM
  #9254
ORIGINAL: w8ye
I do this with most of my engines just as a matter of course. Works like a charm.
jess
Old 12-02-2007, 11:27 PM
  #9255
My Feedback: (31)
Hello:
I'm looking for a crankshaft for my Saito 80, I broke it when I was tightening the propeller.
Do you know who could sell a used one?
My mail: [email protected]
Thnaks
Old 12-02-2007, 11:34 PM
  #9256
My Feedback: (16)
w8ye's Avatar
The 80 has been discontinued by Horizon and it's now hard to find the part on their site but here it is. . . .
http://www.horizonhobby.com/Products...rodID=SAI8023B
You may want to bookmark this link but here are all the Saito 80 parts that Horizon stocks . . . . .
http://search.horizonhobby.com/index...d=1169E563BCE1
There are also parts from some other Saito engines that will fit on the "80"
Old 12-03-2007, 07:02 AM
  #9257
how did you do that ???
c-crunch
Old 12-03-2007, 10:56 PM
  #9258
John Raymond's Avatar
I have two FA 82's, both installed upright, what is the best way to put ARO into the engines?
Old 12-03-2007, 11:08 PM
  #9259
ORIGINAL: John Raymond
There is a crankcase vent nipple that should have a section of fuel tubing attached to it. The fuel line attached to the crankcase vent nipple should be ran out the bottom of your cowl, to allow excess oil to be blown out during use.
The crankcase vent is a brass nipple, on the bottom of the crankcase, just a little bit behind the prop. That is where to squirt ARO into your engine. I use a syringe, but a small squeeze bottle will work too. Just squirt your ARO into the crankcase, and spin the engine to distribute it.
Old 12-03-2007, 11:28 PM
  #9260
My Feedback: (16)
w8ye's Avatar
Finding parts for older Saitos . . . .
It would be nice to have the original manual. But in this case the "80" is in the current manual. Many Saito engines use parts intended for other size Saitos.
Saito parts have a numbering system with Horizon the is the Saito part number preceded by "SAI". The first digit of the Saito part number indicates the engine it was originally designed for. The remaining numbers indicate things like a crankshaft is the number "23". There may be a letter following the 23 if there have been design changes in the part. So a SAI6523B would be the later model "longer" crankshaft for a Saito 65. The 80 would be a SAI8023B .
When searching in the Horizon site you need to "left click" after a complete data entry. The programmer didn't set the database up to accept a "carriage return" after a data search entry like on the Tower site.
The wild card icon to use with a data search on the Horizon site is the "*", Therefore to find all the parts intended originally for the Saito 80 would be "SAI80*" .
Keep in mind that all the valve covers for the 45 through 100 and 125 engines use the Saito 50 valve cover. Likewise these same engines all use the Saito 50 GK venturi extension etc. This is where an original manual (parts list) would come in handy?
Old 12-03-2007, 11:45 PM
  #9261
My Feedback: (31)
Guys!
I'm looking for a Saito 80 Crankshaft anybody has one on sale?
Let me know. Thanks.
Old 12-03-2007, 11:46 PM
  #9262
My Feedback: (31)
Guys!
Old 12-04-2007, 01:32 AM
  #9263
I use a very old oilcan. the kind with a bell shaped bottom and spout that tapers to a point. Just plug the spout imto a piece of fuel tube connected to the breather nipple and turn the engine over a few times. It will pull the oil right in. Then just flip the engine a few times or spin it with a starter to distribute the oil.
jess
Old 12-04-2007, 09:02 AM
  #9264
I was recently breaking in my new Saito 150 and noticed that the engine firewall area was covered with a clean honey colored oil.
This oil was coming from the crankcase nipple located in the backplate. After I put a piece of fuel tubing on this nipple and ran it out the bottom of the cowl, my engine compartment and firewall are very clean after running the engine. I am very happy with my new saito 150.
Just a few changes in the engine design I have noticed and thank Saito for incorporating into theie engine:
Carbuerator intake now has a velocity stack.
Carbuerator intake stack is now mounted by an adjustible swivel attachments very much like the exaust.
These two changes might seem un-noteworthy, but the fact is that on my particular application the adjustible (swivel) intake stack is what made it possible for me to mount my engine at the proper location for an outstanding appearance with the cowl and spinner backplate are attached. Thanks Saito!!
MR G
Old 12-04-2007, 09:29 AM
  #9265
My Feedback: (102)
Hobbsy's Avatar
This is a very early 1990 high compression 1.50, all you mentioned has been true from day one on the 1.50. This one was $449.00 back then, I think they're about a 100 bucks less now.
Old 12-04-2007, 11:30 AM
  #9266
Thanks Hobbsy,
My last Saito engine was a Saito 100, and did not have velocity stack or swivel intake. I thought the changes were recent design changes but obviously I was wrong. Nevertheless I am a Saito fan and Saito performance rocks!!!
MR G
Old 12-04-2007, 11:33 AM
  #9267
My Feedback: (16)
w8ye's Avatar
Saito makes a velocity stack that fits the Saito 100 if you so desire.
Old 12-04-2007, 01:36 PM
  #9268
Thanks w8ye, but I no longer have that engine.
MR G
Old 12-04-2007, 08:06 PM
  #9269
I just got my new (used) .82 in the mail, it's a little oily and dirty, but seems to be in good shape. I'm going to pop the back plate to make sure there's no rust. Call me lazy, but I don't have time to read all 363 pages of this thread again, so I'll ask a question that's been answered before. I remember hearing about possible intake manifold problems due to the plastic back plate, and I remember seeing someone with a "fix", maybe an aluminum spacer or something. Can anyone tell me exactly what the problems with the plastic backplate are, and the fix if they remember. Thanks.
Old 12-04-2007, 08:28 PM
  #9270
I checked with Horizon Hobby a while back and was informed that there was not a velocity stack for the Saito 100, do you have a part #?
bhady
Old 12-04-2007, 09:01 PM
  #9271
ORIGINAL: rexracer
The best thing I can do for you is to post a link to one of Bill Robinson's old posts. No one could say it better than he did!
http://www.rcuniverse.com/forum/fb.asp?m=4451017
Old 12-04-2007, 09:07 PM
  #9272
blw
blw's Avatar
Rexracer- I think those are limited to the .72 and not your engine. At least, I haven't heard of any problems. You could aggravate things by taking the manifold out of the cylinder and cutting the o ring when you reinsert it. On this engine, it is probably best to just fly it.
Old 12-04-2007, 09:22 PM
  #9273
My Feedback: (16)
w8ye's Avatar
The number of the Velocity stack is in this link . . .
http://www.horizonhobby.com/Products...odID=SAI50GK93
Old 12-04-2007, 09:47 PM
  #9274
The pictures in the post I linked to below actually show the difference in the backplates better than in the first one I posted.
http://www.rcuniverse.com/forum/fb.asp?m=4583153
I have not seen any 82's with the older style backplate myself, and I do not know for certain if any were sent out with the old style. I was just going on what Bill wrote.
Old 12-04-2007, 09:50 PM
  #9275
blw
blw's Avatar
Ken,
I wrote that before I went to your link with Bill's comments. I remember that we weren't sure about the backplates on the .82 at that time. The .82 was still pretty new.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
