Welcome to Club SAITO !
Old 09-17-2012, 10:21 AM
  #23176
Default RE: Welcome to Club SAITO !
I have a saito 100 turning a 14x8 APC prop. Ran about threee tanks for proper break-in. The most I have gotten on the high end is 7800 RPM and the low end idles nicely at 3200 RPM. My concern is that I thought I should be running around 8500 as minimum on the high end. Also, i have the engine in a Pulse XT60.
Old 09-17-2012, 01:30 PM
  #23177
My Feedback: (102)
Hobbsy's Avatar
I don't believe you've reached the peak rpm on the high speed needle yet, the LS needle is too rich also but can't be set untill you get the HS right. It should easily idle at 2,000 when set up correctly.
Old 09-17-2012, 03:14 PM
  #23178
i will keep running fuel through (15% omega) and try and to lean in the high end some more. i will keep you posted after work around around 5PM eastern time
thanks
Hobbsy
Old 09-18-2012, 05:25 AM
  #23179
My Feedback: (15)
jkr_1100's Avatar
Just picked up a Saito .50
Put it on a Goldberg Eaglet. TF 11X7 wood. lots of fun.
previous owner had an idle bar plug in it, LSN way too lean, now - What a sweet heart.
ID:	1802481   Click image for larger version
Old 09-18-2012, 10:42 AM
  #23180
Hello,
I have acquired a Saito 45s in a disassembled state. I know, I think I do, how to put it together but there is one piece, a kind of washer, that I don't know where it belongs. Can someone help me with this?
Thanx
ID:	1802542   Click image for larger version
Old 09-19-2012, 04:16 AM
  #23181
Rudolph Hart's Avatar
I think i understand what you are saying.If the lsn is at factory settings and now you have at least three tanks thru it don't be scared to wind the main needle in to peak it,it's frustrating if you can't.Just remember to wait for about seven seconds at mid throttle after each change of needle and you will hear it,use a tacho too.After that the lsn is easier to set and you8 should get 1800 reliably with little effort,you can hear that happen and it sounds so right you hardly touch it again.
Old 09-19-2012, 04:31 AM
  #23182
My Feedback: (65)
Have to agree. After tuning my FA-45S it's ticking over at 1800-1900 nicely. Oh yes, Saito forum is back to normal.
Old 09-19-2012, 06:13 AM
  #23183
It rained here (upstate NY) pretty much all day and I have not had a chance to go back at it. Today is a better day, and I plan on tweaking the engine some more to try and get more out HS. I am using a tach to get my RPM readings and it sounds like I just need to tweak the HS needle in more to raise my RPMs past 7800. I am hearing that anywhere between 8500 - 9200 is good, and can get better as the engine breaks in more. The LS anywhere between 2200 - 2800 is good and can get better as well.
thanks for all the advice and I will let you know later tonite or Thursday AM how things went. I am hoping to do a maiden flight of my Pulse xt60 Friday Afternoon.
Old 09-19-2012, 08:21 AM
  #23184
My Feedback: (65)
I made it !! Started at page 1 and here I am. Thanx to you all for the vast information posted here. I would like to join the club. I have: 72, 80 x 2, 82a, 82b, 91, 100 x 3, 115 x 2, 125 x 2, 180, FG20, and am in the process of getting a FG17.
Thanx to the "Hobbsy" method of break-in, my 91 is running sweet. Still breaking it in. Thanx Hobbsy.
One of my 80's was supposedly used, bought it several years ago. So I ran it trying to find a good prop, never ran it lean. After a while, it started running weird, high rpm's were changing, and getting a little black smoke. Then I figured that the engine must have been new, and I ruined it. I'm going to set it on a shelf, and tear it apart when I need to learn how to disassemle. Lot's of good advice here when the time comes. The other Saito's I haven't run yet. My next one is the 72 to break in, putting it a H9 Twist 40.
Thanx again to all of you for the time posting, helping all.
Cheers
Old 09-19-2012, 02:23 PM
  #23185
My Feedback: (19)
Hobbsy,
I have experienced problems entering this forum and two other fora to which I subscribe since August.
I have contacted customer service several times and I am happy to report that after RC Universe closed down the
fora last night and correcting the malfunction, my access is now complete and I think that of many others is
now functional again. At least I hope so!
I do have one other comment and that is that the last five pages in this forum are listed as "page 916."
Old 09-19-2012, 03:16 PM
  #23186
Hello Krop et al,
Tonight was the first successful log-in that I've had in weeks. Thanks to the folks at RCU for correcting this.
Bob
Old 09-19-2012, 03:33 PM
  #23187
Well I tried to tweak in the HS and I could not get the rpms to go over 7800. However, the LS did idle nicely at 2000 rpms. I am hoping that my pulse xt60 will have enough power from satio 100 at 7800 rpms.
  #23188
My Feedback: (102)
Hobbsy's Avatar
You're welcome gents, all. I changed to Google Chrome a few weeks ago and did not have any of the difficulties mentioned although McAfee gave me a warning when going to the MarketPlace but that too has gone away.
Ric, glad the break in process worked, it has for on more than 40 Saitos my own and many others. Some think its too involved but to me its the best 40/50 minutes of an engines life. Its fun to actually listen to engine come alive.
Old 09-19-2012, 03:35 PM
  #23189
My Feedback: (102)
Hobbsy's Avatar
It will and then some.
Old 09-19-2012, 05:33 PM
  #23190
mike early's Avatar
I scrolled back but could not find what prop you have on that Saito 100? Saitos like to turn more RPMs than 7800
Old 09-19-2012, 05:39 PM
  #23191
blw
blw's Avatar
Default RE: [Deleted]
I suggest that the new Saito's get some healthy wide open runs when using Dave's break in rpms. They will take it and sound good as they loosen up.
Old 09-20-2012, 02:51 AM
  #23192
Mike,
I am spinning a 14x8 apc prop as it outlines in the break-in instructions. After 7800 rpms and trying to tweak a little more it try's to die out and I back off on the HS needle to where she is running between 7600-7800 rpms.
Old 09-20-2012, 03:42 AM
  #23193
Dave w8 and others are right as said above but you have a fuel supply problem somewhere if you are tuning the needles right,as an example for you to compare i run 2 82 a and b engines in a 65" decathlon and ground prop speed is in the mid eights to nine with an apc 14x6,you should be getting a lot more on a 14x8..is it a wide blade prop?
Richochet rabbit welcome and good luck with your engines,a nice selection.How many others have taken up that much time to read all the pages is this thread i wonder,apart from the mods who have given their time and energy to it? cheers guys
Old 09-20-2012, 05:01 AM
  #23194
I have a black horse birddog which is advertised at 7.7# and using a 90 four stroke. Which saito would work well? Which twin would work? Thanks.
ID:	1803146   Click image for larger version
Old 09-20-2012, 06:39 AM
  #23195
SrTelemaster150's Avatar
ORIGINAL: skypup50
I'm flying a US Aircore "Nighthawk", a coroplast high wing. W/a Saito 91S if flies great so far, but I'm still rusty after a 14 year hiatus so I'm still on the buddy box. It weighs just over 7#. The FA91S swings a 15 X 4 Zinger @ 10,300 RPM on glow ignition, 10,500 on spark. It will take the plane staright up from stationary out my hands on either & I would expect the vertical to be near unlimited.
ANY Saito single from 91 up W/the right prop should give similar or better performance on your Bird Dog.
BTW: What's the WS?
If you are looking for a more scale like performance twin cylinder envelope, the FA90T, FA90TS or FA100 Twould fit the bill also.
Old 09-21-2012, 03:05 AM
  #23196
I agree.I'd pick the 90 twin with the offset cylinders and broken down veedub engine sound,would probably power it scale as well.
Old 09-21-2012, 03:13 AM
  #23197
Hobby,
I did my maiden flight with my pulse XT60. The satio was at 7800 and pulled the plane around but not with authority. You could tell the sa100 was u der power. I checked to make sure full throttle was at full throttle on the carb and it was. The LS was idle nicely at 1900-2100 RPMs. Try tweaking the HS and the engines want to die.
Old 09-21-2012, 04:39 AM
  #23198
I think he means you dave
Old 09-21-2012, 07:22 AM
  #23199
mike early's Avatar
Is it a new engine? We got some valve problems? Bad fuel? Something is amiss, for sure.
Old 09-21-2012, 08:12 AM
  #23200
ORIGINAL: mike early
Definately something amiss as the prop/RPM idicates that he is only producing about 1HP.
A 14 X 8 should be turning about 9000 RPM @ 1.5 HP output.
A Saito FA100 should easily make 1.5 HP.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
