Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 03-09-2017, 03:53 AM
  #51
i3dm
My Feedback: (51)
Fabricated a simple vertical stopper above the fuel tanks, to keep them from moving upwards.
(didnt want to glue tanks to bottom of fuselage, although its a simple possibility).
ID:	2204592   Click image for larger version
ID:	2204593   Click image for larger version
ID:	2204594   Click image for larger version
Old 03-09-2017, 10:13 AM
  #52
Ceeray
To Skytoys which is prolly following the topic... :
Any chance for scale jets like t-50 golden eagle or F-18 with similar size as these new offerings?
Sorry offtopic.
Old 03-09-2017, 10:56 AM
  #53
i3dm
My Feedback: (51)
Main equipment tray is very big and spacious, i cut it in half to allow easier disassembly. i also primered it Grey.
Fuel tanks have anti slip velcro between them, and are held down from top with a plywood bracket which i fabricated.
ID:	2204639   Click image for larger version
ID:	2204640   Click image for larger version
ID:	2204641   Click image for larger version
Old 03-09-2017, 10:58 AM
  #54
i3dm
My Feedback: (51)
My order from Emcotec came right on time with the DPSI RC Mini 5 Magic.
This, coupled with the Cortex Pro, would make a high power, 12 channel SBUS2 telemetry capable setup with servo matching! all out of a single R7008SB Rx!
Old 03-09-2017, 11:04 AM
  #55
Sky Toys
Sky Toys's Avatar
Sorry offtopic.
Hello Ceeray,
Top RC makes several scale jets: G4 Super Galeb, F9 Cougar, Hawker Hunter, and also several prop planes.
there are several new scale jets in the making, and more suprises...
ID:	2204644   Click image for larger version
Old 03-09-2017, 02:36 PM
  #56
rgburrill
rgburrill's Avatar
Please see the thread Damiano F-86. That is a build! This is an assembly.
Old 03-09-2017, 03:22 PM
  #57
mups53
My Feedback: (41)
Hi Guys and thanks for the intro to this thread Lior
Caiman Distribution which is a new company that is 50/50 Gator-RC and Robart Mfg. (retracts) is the exclusive distributor for all things TopRCModel in North America.
Our website is up but still under development. It's nearing completion in probably a week.
You can view it at caimandist.com
We have the Odyssey coming on our next shipment. For now, we are fully stocked with 4 versions of the F9F Cougar, and Super Galeb Jets.
We also have a decent supply of the P-51D 5th scale in 3 paint schemes the GunFighter, Old Crow and Blondie as well as the Spitfire and A6M Zero fighters.
If interested feel free to contact me directly to obtain any of these beautiful planes.
Thanks, Mike Mueller
800 380 9313
[email protected]
Name:	Wram show-1.JPG
ID:	2204659   Click image for larger version
Name:	Wram show-2.JPG
ID:	2204660   Click image for larger version
Name:	Wram show-3.JPG
ID:	2204661   Click image for larger version
ID:	2204662   Click image for larger version
ID:	2204663   Click image for larger version
ID:	2204664   Click image for larger version
ID:	2204665   Click image for larger version
Old 03-11-2017, 03:01 AM
  #58
i3dm
My Feedback: (51)
I have covered the tail section harnesses with heat protective sleeves, and routed them in tail section.
while at it, installed the permenanat connectors for tail section (elevator and rudder servos) and the rear plywood former (that holds the pipe) + AB LED ring.
ID:	2204863   Click image for larger version
ID:	2204864   Click image for larger version
ID:	2204865   Click image for larger version
Old 03-11-2017, 08:00 AM
  #59
Canadian Man
Canadian Man's Avatar
Tagged to follow
Old 03-11-2017, 08:55 AM
  #60
Sky Toys
Sky Toys's Avatar
Originally Posted by Canadian Man
Tagged to follow
Old 03-11-2017, 09:26 AM
  #61
Ceeray
Originally Posted by Sky Toys
Hello Ceeray,
Sounds Good and promising.
A large Bf-109 G , Fw-190 D9 from warbirds are on my list. Also jets of course, but mainly a bit newer generation of jets. And back to interesting topic!
Old 03-11-2017, 10:02 AM
  #62
i3dm
My Feedback: (51)
wiring harnesses.
ID:	2204904   Click image for larger version
ID:	2204905   Click image for larger version
ID:	2204906   Click image for larger version
ID:	2204907   Click image for larger version
Old 03-11-2017, 10:04 AM
  #63
i3dm
My Feedback: (51)
Front tray making some progress, and cockpit test mounting after front tray components have been installed - ALL A-OK !!
As a power system i have chosen the Emcotec DPSI RV Mini 5. should be a great combo with the Cortex Pro!
Name:	tray cockpit (1).jpeg
ID:	2204909   Click image for larger version
Name:	tray cockpit (2).jpeg
ID:	2204910   Click image for larger version
Name:	tray cockpit (3).jpeg
Old 03-12-2017, 12:18 PM
  #64
i3dm
My Feedback: (51)
Bavarian Demon Cortex Pro Install.
ID:	2205067   Click image for larger version
ID:	2205068   Click image for larger version
ID:	2205069   Click image for larger version
Old 03-13-2017, 08:18 AM
  #65
i3dm
My Feedback: (51)
Got the ATJ 140SV powerhouse engine installed
Name:	engine cable.jpeg
ID:	2205185   Click image for larger version
Name:	engine center.jpg
ID:	2205186   Click image for larger version
ID:	2205187   Click image for larger version
Old 03-14-2017, 01:19 PM
  #66
i3dm
My Feedback: (51)
Power Harnesses ffor the Emcotec done.
color coding and dymo lables for extensions done.
and Emcotec magnetic switch installed.
I also added a picture showing the access to the fin bolt.
Name:	cg odyssey (1).jpeg
ID:	2205324   Click image for larger version
Name:	cg odyssey (2).jpeg
ID:	2205325   Click image for larger version
Name:	color code.jpeg
ID:	2205326   Click image for larger version
ID:	2205327   Click image for larger version
Name:	mag switch.jpeg
ID:	2205328   Click image for larger version
ID:	2205329   Click image for larger version
ID:	2205330   Click image for larger version
Name:	emcotec power.jpg
Old 03-14-2017, 01:22 PM
  #67
i3dm
My Feedback: (51)
CG was check for 210mm and i found that i had to install all 3 batteries in the nose:
1 x 2S 5000mah Lipo for turbine
2 x 2S 2200mah Lipos for Rx
and also about 240g of lead weight.
on my next Odyssey install i will mount the UAT further forward and require no ballast!
I wrapped all 3 packs in heat shrink together and they are inserted as one block and velcroed to nose cone bottom from inside.
ID:	2205332   Click image for larger version
ID:	2205333   Click image for larger version
Old 03-14-2017, 01:35 PM
  #68
i3dm
My Feedback: (51)
batteries harnesses
Name:	batt harnesses.jpeg
Old 03-17-2017, 10:19 AM
  #69
pcskyhi
Default Tank fittings
Originally Posted by i3dm
I decided to use FCT fittings on the fuel tanks - saw this at Jetpower and thought i MUST have them on my next jet.
here is how these jewels are mounted:
Where did you acquire those fittings. I like the fact not necessary to safety wire. I found the clunk at DreamWorks RC but they did not have these fittings, not yet.
Old 03-17-2017, 10:21 AM
  #70
i3dm
My Feedback: (51)
I ordered them from Saleem Siddique on facebook, he is the owner of FCT.
Old 03-17-2017, 10:37 AM
  #71
i3dm
My Feedback: (51)
She flys great !!
This morning in Mevo Horon, 2 wonderful maiden flights to the Top Rc Odyssey sport jet.
im happy to say the model flys very well, and with a few small setup tweaks im sure we will have a serious winner here!
Odyssey by Top RC
ATJ 140SV
DPSI Mini 5 Magic by Emcotec
Cortex Pro by Bavarian Demon
UAT and fuel fittings by FCT
Blue-Bird BLS-3507 servos all around.
Futaba 18MZ radio with my own Turbine telemetry
Had lots of fun, cant wait to fly it again!
Special thanks to:
Sky Toys Zvika Jan
The magician Dudu Ifrah
ID:	2205772   Click image for larger version
ID:	2205773   Click image for larger version
ID:	2205774   Click image for larger version
ID:	2205775   Click image for larger version
ID:	2205776   Click image for larger version
ID:	2205777   Click image for larger version
ID:	2205778   Click image for larger version
Old 03-17-2017, 12:00 PM
  #72
i3dm
My Feedback: (51)
Flying video from today:
https://www.youtube.com/watch?v=g_wTHHMFlxo
Old 03-17-2017, 02:20 PM
  #73
GULDUKAT
Congrats. Nice flying.
Old 03-17-2017, 10:22 PM
  #74
pcskyhi
Thanks for the info.
How would you compare the quality and flight characteristics of the Odyssey and the T-1 you built. I noticed you fly them the same way, very relaxed and slow. When you fly the Ultra Flash you fly it like a scolded cat but these last two models are being flown with a lot of poise and grace. Are these models not designed for the kind of stresses you put the Ultra Flash through? The Odyssey reminds me of a Habu 32 which is a slick airframe and those same dark red and black colors make it hard to see (at least for me) In your video It only stood out on your slow and low passes otherwise all I was seeing was the profile of the aircraft.
Last question, how hard/easy or is it even feasible to transport this aircraft as a two piece fuse? One you arrived at the field, would you struggle getting set up for flight?
Thanks for the build thread. Your thread will probably have some people taking a hard look at this bird.
Old 03-17-2017, 11:33 PM
  #75
i3dm
My Feedback: (51)
That is actually a great question and i am very happy you asked!
The T1 / Odyssey are in fact different from the UF.
The UF is designed to withstand extreme loads, and flys completely different then these two. Faster and heavier. A 2.4m odyssey weighs nearly the same as a 2.1m UF!
The T1 and Odyssey are more of the modern style sport jets, for more "floating", slower precise aerobatics.
While both are quite capable of flying fast, they are not a UF in that sense. The odyssey is faster than the T1 though.
With that being said, the flying i do with both is where i feel comfortable, part of the UF speed experience is that i never felt comfortable flying slow aerobatics with it (did like the high speed stuff!), while with these the more graceful flying feels right at home. So naturally this ia where my flying style goes when i fly them, and im very happy with this transition.
Another reason for at least the Odyssey flying being a bit more cautious in these videos is that these are just the first 2 maiden flights, of a new model i dont know well yet, and is not yet 100% tuned (CG, control throws) to my liking. So once i get a few more flights in, i will surely make more videos, of higher speed flying also.
Bottom line, they are all great models, the odyssey is much bigger than the UF, feels much lighter, and easier.
If you want to fly like a scolded cat, get a UF and if you want a larger, easier floatier sport jet with great capabilities (significantly cheaper too) get the Odyssey.
About the 2 piece fuselage, while i didnt build mine as a 2 piece design, im sure that if you do, it will be very easy to assemble.
The 2 piece fuse assembles together with 6 M6 screws and you can build the entire fuel system on the back fuse, with only electrical wiring connectors at the joint.
Thank you for the feedback, i do appriciate it very much, and look forward to enjoying this new exciting jet and sharing the results
polishedbrother (12-17-2023)
